Idea parabolic dome design/dimensions
  • di11on
    • May 2014
    • 109
    Hi folks,
    I've read before that the oven dome should have a parabolic cross section.
    This seems to make sense as all heat rising upwards is reflected downwards to the focal point... the same principle as a satellite dish. So, where should the focal point of the oven be... where you're going to put your pizza/bread? If so, where is this exactly? Right on the oven surface in the centre, or slightly above or below?
    My oven on a pallet build thread
  • jeeppiper
    • Mar 2011
    • 321
    Re: Idea parabolic dome design/dimensions
    I don't think it works quite like that. The heat transferred from the dome is mostly convective and it is not reflective or radiant heat.
    Also, I would think you would want to avoid having a focal point
    'hot spot" because you want even heat distribution throughout the oven.
