Hi all - I've been dreaming of building a WFO for years but finally getting around to it now (mostly because I've got a couple of tons of concrete rubble to hide that I'm putting into the base =D ). Was hoping you guys might be able to throw me a little advice?
I started with the intention of building an entirely clay & cob one, following the river cottage model (don't know if you have that show in the US). The one I've seen that is closest to what I have in mind is Capt Jon's excellent oven on this forum, here: http://www.fornobravo.com/forum/43/c...n-19828-4.html - only I was intending to use cob insulation rather than vermiculite/ concrete.
The decision I'm trying to make is whether to use brick instead of cob - mostly because clay is more of a pain for me to get than brick (I live on chalk geology and the nearest clay subsoil is a good way away; hopefully I also have a pretty large free supply of old red solid bricks). Cost is a big factor - I want this to be pretty inexpensive, and don't intend to buy expensive firebricks. I'd like it to last a few years but I'd rather rebuild another later, than blow hundreds of ? on it now. From what I've read old red solids should do the job: Alternative for Fire Bricks are the old red clay solid bricks. Firebrick substitute
OK to get to the point - my alternatives are, for inside of dome/ insulation/ outer skin:
Cob version: Clay & sand mix / clay slip & woodshavings / clay & sand mix (and a roof to protect it as it's obviously going to weather)
Brick version: Brick dome (using FB recipe ref. mortar I guess) / some sort of insulation (?rockwool held with chickenwire) / vermicrete?/ stucco
The base I'm pretty confident with (reinforced concrete slab, insulating layer, bricks set in thin layer of sand).
Comments very welcome and advice gratefully received!
