Chimney and vent size
  • Chimney and vent size
    I am building a 45" pompeii oven in Denmark right now and I am getting to the part where I have to decide on the chimney and vent size.
    The door to the oven is 21" wide and now I am wondering which size the chimney should be.
    Is there a general rule to this?
    The chimney will be a non insulated black painted steel pipe (the ones normally used for WF stoves) around 1 meter high. My thoughts are that either a 6" or 8" would be fine.
    And how wide should the vent leading up to the chimney be?
    Thank you for your input
    Br. Joergen
    Re: Chimney and vent size
    Six inch vent on a 45" oven is too small.
      I have a 6inch chimney on a 32 inch oven and I almost went bigger. I'm with Utah you definitely want 8 inch.
      The area of the vent needs to be BIGGER than the area of the chimney. An 8 inch chimney has an area of 50 square inches - so you want to be bigger than that for the vent; For instance 10 inches by 6 inches.
