How safe is the insulation
  • minshall5j
    • Aug 2014
    • 7
    I'm starting to plan my wfo build and have a few questions about insulation. From what I've read I understand the importance of it so want to get it right.
    How safe is the ceramic insulation board/blanket? I think I understand the need for mask during the building stage but what about after it's built. Are there risks to health?
    Vermiculite could be an option but from what I read it seems some ppl say it's not that much better
    Are their any alternatives that are safer, I wouldn't mind if it means my walls are a lot bigger.
    Re: How safe is the insulation
    The proper PPE (Personal Protecton Equipment) , shoud be used in any, and all phases of the build. Dust, from the blanket, vermiculite, or even play sand should not be breathed. A simple dust mask should be enough to take care of the inhalation hazards. Orienting the brick saw down wind from where you stand while operating it will be a great help. You can buy disposable painters coveralls, if you are worried about tracking something into the house. Once the insualation is sealed underneath and over the oven and the dust has settled from the brick saw, there is no health worries .
    • minshall5j
      • Aug 2014
      • 7
      Thanks for the information
      However what about after it's been installed. I understand it's encased but over the lifetime of the wfo with potential for parts to degrade is it a problem. Or am I worrying about nothing
      • Tscarborough
        • Oct 2009
        • 3341
        You should not build an oven, it will kill you, if the Global Warming or Eggs don't get you first.
        • Laurentius
          • Nov 2010
          • 923
          Hi Minshall,
          The ceramic products are no greater or lesser health risk than any other of the components used to construct your oven if you use proper precautions. There are guidelines that you should follow, inhaling ceramic fibers, brick dust, vermiculite dust, cement dust, concrete dust, acid fumes and water can all cause serious health problems and even death. Always protect your lungs, eyes and skin from caustic and irritating materials, be careful.
            Maybe not in your lifetime, but if there is a a future discovery, hopefully they will also have a cure .
            • minshall5j
              • Aug 2014
              • 7
              After seeing first hand what happens when it goes wrong, and especially when for years ppl said asbestos was safe I thought I should at least ask the question.
              No harm asking
              • Laurentius
                • Nov 2010
                • 923
                Hi T,
                May I add? Nor live outside a bubble. Living leads to death!
                • minshall5j
                  • Aug 2014
                  • 7
                  Thanks that's helped a lot with it all. Appreciate it.
                    No harm asking
                    Actually you are right in asking. I'm sorry to make light of your question. I was just trying to assure you that the "recommended" insulations and masonry materials are fairly safe, if installed properly .
                    • Tscarborough
                      • Oct 2009
                      • 3341
                      If it bothers you, use perlite instead.
