Block stand height
  • Danno
    • May 2013
    • 3
    Block stand height
    Hello everyone, just wondering if there would be any issues with structure or stability if the block stand were 5 courses high, rather than 4 courses high. Reason I ask is because I'd like to build an attached counter that was the same height. I am using the pompeii oven plans, for a 36" oven. Would I need a wider foundation and base, or would the dimensions in the plans still be ok, with the increased height? Any opinions and suggestions would be greatly appreciated. Thanks very much.
  • vtsteve
    • 110
    Re: Block stand height
    It will be fine.
    • DavidApp
      • Sep 2012
      • 348
      Hello Danno
      Did you know that it is possible to buy 1/2 height blocks. 4" in stead of 8" You may have to go to block company instead of a big box store.
      That may give you more options on the Block stand height.
      David
        • 9211
        Five blocks tall is no problem, check this one out.
