heat loss 32" oven
  • strobes
    • Jul 2014
    • 62
    heat loss 32" oven
    Amount of BTU lost in 24 hours at 1000F with 40 square foot of surface and 3" of Insboard 2300LD insulation = 0.85 Thermal Conductivity x24hr x 40 sf / 3" = 272 BTU
    If radiated heat loss comparable to the convection heat loss, then total heat loss in 24 hours is about 350BTU.
    Somewhere else on the forum I found that oven absorbs about 70000 BTU when brick saturated @900F.
    At this rate of heat loss it takes about 200 days for oven to cool. But in reality an oven cools in 4-5 days. (rate of loss 140000BTU.)
    That is huge difference between calculated and empirical?
  • wotavidone
    • May 2011
    • 800
    Re: heat loss 32" oven
    Take one of your fire bricks and put it on the ground.
    Put your calculator on the brick. Take another brick and smash the S@#T out of your calculator. When the calculator is reduced to unrecognisable fragments, take the rest of your bricks and build an oven.
    Just sayin'
    • jeeppiper
      • Mar 2011
      • 321
      Soooooo your point is.......?
      I say, "Don't worry about it. Does you oven cook pizzas or doesn't it?"
      That is the real question.
      • strobes
        • Jul 2014
        • 62
        I'll let you know how much i spend. how long to build and how many days it will stay hot.
