Entry floor tile
  • Entry floor tile
    I have a question that someone else asked in another thread but wasn't answered. In my build as I am planning it the cal sil board extends out of the oven area and would be under my entry floor bricks, could that be a issue for moisture getting into my floor insulation, as I know the dome would be waterproofed but the entry way is exposed to rain that could leach thru the floor brick and into the insulation. Could this be an issue.
    Thanks Bill
    Re: Entry floor tile
    If water is going to get into your entry it wouldn't matter what was under the floor. A couple of litres of water is a couple of litres and has to find its way out. I'd go with calsil under the entry too.
      Thanks Daved
      I just didn't know how hydroscopic Cal-Sil is
        Bill, the stuff is a sponge. When it dries it is back to norm. I have the board in my entry and I have no issues. Where you live it may be a problem unless you can keep the project covered? You get wet all year round.
          Usually rains at least once a day but not hard until the rainy season when that comes it can be wet for weeks, live on the side of the mountain back in a valley. Might have to make a second door when not in use.
          Bill
            Hello Bill
            I presume that a rain cover on the chimney will help to stop water getting into the oven and the insulation under the entry way.
            I have noticed that where some of my fiber board got a bit wet it took days to dry out.
            David
