Re: New NorCal build
That Quikrete will just fine for filling the cores and securing your vertical pieces of rebar. It takes, surprisingly, quite a bit of concrete to fill those cores. I used a harbor freight cement mixer to mix min but still had to use the wheel barrow to get it over to the block stand. I just used a spade shovel to lift and drop it down in. I've seen guys cut out some scoops out of empty milk or laundry soap jugs. Those looked like they worked pretty slick. For mixing in a wheel barrow, an old garden hoe works well.
