Hello Proc
Not sure about the width but the height is important. It should be about %63 of the dome height so 16" is a fraction high if you have a true hemisphere.
The arch position will affect how it ties into the higher chains of the dome. I inset my arch into the dome a bit so that the higher courses met the arch using the same width bricks. If you set the arch further out you will have to extend the higher arch bricks to meet the dome bricks.
Both ways work.
David
Both ways work.
David
