Struggling to get portable oven temp
  • branded
    • May 2014
    • 12
    Hi Guys,
    I bought a cheap portable (I'm renting) wood fired oven made from sheet metal and it is somewhat insulated. I know... I know... I know it's not brick, but I think I should be able to get it to 450C degrees if I modify it.
    I have drawn up roughly how it's made here: http://i.imgur.com/48kT9R4.jpg
    Basically is a half barrel sheet metal oven with insulation between the sheet metal. I believe it's fully insulated in the roof/sides, back and on the door. On the floor, it came with fire bricks on top of an uninsulated sheet metal floor, so there's only fire bricks on the floor - nowhere else, the rest is sheet metal. I bought 25mm of calcium silicate and laid that between the fire bricks and sheet metal floor - so it should now be insulated everywhere. But I'm still struggling to get it to 450C, I get maybe 350C, maybe more if I go crazy with wood..
    Is it because the dome is not brick? I know it may be a dumb question, just asking. What do you think I could do? I really thought this would have potential if I modify it.
    Thanks!
  • okn
    • May 2011
    • 133
    Re: Struggling to get portable oven temp
    My vote is to add more wood.
    • branded
      • May 2014
      • 12
      If you look at the oven plan image I provided, I'm putting enough wood to cover eight bricks and as high as the roof.
      • okn
        • May 2011
        • 133
        That sure does seem like plenty, what kind of wood are you using? Are you talking about 450C on the floor or dome? I think you'll have a hard time with 450C on the floor, unless it's a big fire for a long time 3+ hours
        • branded
          • May 2014
          • 12
          I'm using red gum. Any wood recommendations for an Aussie?
          • branded
            • May 2014
            • 12
            I got close, check the results here:
            http://www.fornobravo.com/forum/f25/...rly-21706.html
