SuperIsol Installation for 42" Pompeii
  • #16
    Re: SuperIsol Installation for 42" Pompeii
    I concur with David - it's nasty stuff. I had only straight cuts, so noise wasn't a problem - a fine toothed hand saw went through it easily. For a circle, a jigsaw with a fine blade would probably be the way to go, or a fine keyhole saw. This stuff is brittle, and it chips and dents easily, especially at the start and end of cuts!
    • #17
      The mask sounds like a great idea for that product - in regard to noise, I've been to a few too many Black Sabbath concerts for that to be an issue.
      So far, I've been cutting my pavers and island brick without a mask - after my shower, my nose is clean, so that's probably a good indicator that the wet saw is working (I hope).
      Les...
      • #18
        Just don't lean in too close to the mist...or turn the pump volume down just a bit to avoid the mist (thats what I did). I can't stand wearing a mask in FL heat and humidity.
