Kaowool Refractory Ceramic Fiber Insulating Board
  • Ken524
    • May 2007
    • 1655
    UPDATE - 12/20/2007:
    After completing my oven, I can NOT recommend using Kaowool board under the oven. Due to moisture in the board, parts of my oven are settling (sinking) into the moist, mushy board and causing cracks and joint failures. Please: Don't use this stuff!!. Stick with vermiculite concrete or the SuperIsol sold by Forno Bravo.
    I think I may be the one of the first to use Kaowool rigid insulation board under my oven so I thought I would do a review of the product.
    When shopping for the board, I had a choice between 1" CalSil board (stacked to get 2") or 2" thick Kaowool. I went with the Kaowool so I wouldn't have to monkey with stacking CalSil sheets.
    Manufactured by Thermal Ceramics, the product is shipped 3 sheets to a box. Dimensions are 2' x 4' x 2". Several grades of board are available. The stuff that was available to me was Kaowool M - Low Temperature Board (2300 degrees F). Spec Sheet
    Price was $10USD/SqFt (very high).
    Comparing the spec sheets of SuperIsol and Kaowool, it looks like the SuperIsol is the stronger, sturdier of the two products (I'm not much of an engineer... if anyone can do a real comparasin of the two sets of Spec numbers, I would appreciate it!) I can push my thumb into the Kaowool and feel it "give" with a few pounds of pressure. I don't think there will be a problem with supporting the oven. When dry it's pretty dense. If the dome sinks at all, it won't be more than a few millimeters. I really doubt it will. Too much surface area.
    The board was easy to cut with a jigsaw and light enough for one person to comfortably handle.
    Positioning the floor bricks on it was easy. There is a level, smooth, dark side and a slightly textured, lighter colored side. A friendly engineer at Thermal Ceramics told me either side can face the heat. I also told him what I was doing with the board and he said it should work just fine.
    I have not used SuperIsol/CalSil board. But from reading about others experience, it appears that the Kaowool is more susceptible to moisture damage.
    This picture was taken after I finished gently sponging the excess mortar from my brick.
    Once wet, the ceramic wool really gets soggy and easily comes apart. Each time I got near it with the sponge, some of the dark, smooth surface flaked away. After an hour or so in the sun, it returned to it's original firm state.
    My analysis: I think this stuff will work fine. After everything is sealed up, I don't anticipate moisture will be an issue. The Kaowool is more expensive than other competing products (WAY more expensive than vermic-concrete). If I did it over again, I would go with the double set of 1" CalSil sheets or even the vermiculite.
    Ken H. - Kentucky
    42" Pompeii
  • Archena
    • Apr 2007
    • 1214
    Re: Kaowool Refractory Ceramic Fiber Insulating Board
    Probably would work great for an indoor oven...
    ~runs off to bookmark page~
    [/CENTER]
    • rlf5
      • Jul 2007
      • 322
      Your boards seem to perform about the same as mine. I was able to get a box, more than enough material, of 6 or 8 sheets for $96. They were 12"x36"x2" boards. I started mortaring today, but I didn't put any mortar on the bottom side of my floor bricks. Should I be doing that?
      Oven Progress
      Bread Photos
      Oven Stand Thread
      • Les
        • Sep 2005
        • 2945
        RL,
        I just used the clay sand mix to level out the seams on my boards. If you are level, I don't think you will have any issues. Ken brings up a point of concern though about it getting wet. What's going to happen to us when rain / snow flies into the entry way. I think we are going to need a cover to protect that part of the oven. Just another project for the project
        Les...
        • Ken524
          • May 2007
          • 1655
          I don't have any mortar between any bricks and the insulation boards. I leveled the floor bricks where necessary with fire clay (reclaimed from my HF saw).
          My soldier course is sitting directly on the board. It's firm and level. As it's been said before, gravity will assure the dome won't be going anywhere!
          Ken H. - Kentucky
          42" Pompeii
          • Ken524
            • May 2007
            • 1655
            Originally posted by Les
            RL,
            I'm not too worried about moisture entering the dome and getting below the floor. I'm definitely building a door for the oven that will stay in place when not in use. The floor bricks under my vent and landing will be mortared for weather resistance.
            Ken H. - Kentucky
            42" Pompeii
            • rlf5
              • Jul 2007
              • 322
              Oh then that must be your sand/clay mixture. My mistake!
              Oven Progress
              Bread Photos
              Oven Stand Thread
              • Ken524
                • May 2007
                • 1655
                I'm not sure what you mean... I'll clarify just to make sure: The floor bricks that are under my vent and landing will be sitting directly on the insulation board like the others. I will use HeatStop to mortar these bricks together to inhibit moisture intrusion through the cracks.
                Ken H. - Kentucky
                42" Pompeii
                • rlf5
                  • Jul 2007
                  • 322
                  Oh i see where the confusion is coming from. The top of your boards are a totally different color than the middle of the board. That dark top part of the board made it look like a layer of mortar under the bricks. Again, my mistake.
                  Oven Progress
                  Bread Photos
                  Oven Stand Thread
                  • Ken524
                    • May 2007
                    • 1655
                    Ahhh... Got it. Yeah, the boards have a dark, flat side to them. Looks like dark 60 grit sandpaper. The other side of the boards are cream colored and textured.
                    No problem! Happy to clarify.
                    Ken H. - Kentucky
                    42" Pompeii
                    • asudavew
                      • Jul 2007
                      • 1880
                      Good post.
                      I can't justify the expense of using a fiber board, but you made me feel better about vermiculite!
                      I got some bricks today!!
                      woohoo!!
                      gonna post some pics
                      My thread:
                      My costs:
                      My pics:
                      • Ken524
                        • May 2007
                        • 1655
                        Originally posted by asudavew
                        Good post.
                        Vermiculite has a lot going for it. You won't have to worry about the moisture issues and it's tried and proven. If I did it again, I would build a 4" high form on top of my stand roughly the shape of the oven (maybe a bit bigger) and pour the vermiculite/portland mixture in. That way studs can be attached directly to the concrete if desired.
                        The money I spent for the Kaowool board should have been saved for finishing touches. Live and Learn (and have a blast doing it!)
                        Oh... and don't forget; after you pour the vermiculite, make sure you post a message saying "This stuff is really weird, did I do this right?"
                        Ken H. - Kentucky
                        42" Pompeii
                        • asudavew
                          • Jul 2007
                          • 1880
                          Dude, that made me laugh my butt off.
                          That's my plan Ken. I'm gonna use Masonite as the form. But I'm not sure how to anchor it. I'm thinking about just using wet clay balls to hold it in place....and let them dry. They will be easy to remove and wash away. And maybe some bricks around it.
                          Still thinking about it though.
                          My thread:
                          My costs:
                          My pics:
                          • Les
                            • Sep 2005
                            • 2945
                            Dave,
                            I was planning on going that route as well but went down the insblock path. I was going to cut a few pieces of wood to support the form and ram set them into the hearth. They can be remove fairly easy - just a thought. Wet clay balls just isn't as cool as firing off a few rounds... Plus you neighbors come out side wondering - what the hell was that..
                            Les...
                            • jpar
                              • Oct 2007
                              • 29
                              correct me if I am wrong, but isn't the new FB board a kaowool board equivalent?
