Re: It begins!
I poured my footing for the foundation today. This was my first time working with concrete, so I wasn't sure what to expect. I decided to have it delivered. It took 1.7 Cubic Yards to put a 12 inch deep, 16 inch wide footing down. I'm glad I paid the extra cash to have it brought in.
The company pulls curbside, so we had to wheel it to the back yard. I recruited two helpers. It actually went fairly quickly. Twenty minutes, and he was gone. The concrete was much thicker than I had anticipated. They told me the concrete for footings is typically much coarser and stiffer than other applications, and that watering down any makes it weaker.
I had set up some wood frames above grade to act as a remote screeding system, similar to what Dick built. Dick's was built much better, mine didn't work as well. I think the coarseness of the concrete made if fairly difficult to work with. All in all, it went well. If I had to do over, I would push in pieces of rebar (vertically) periodically in the trenches to use as level guides, as Chuck mentioned above. As I've been told, their will be plenty of opportunity to level out as I build up.
I did end up using rebar in the footing. It seemed to be relatively inexpensive. I had received mixed advice, so I went the conservative approach.
Time to order some blocks!
