View Post
Got these firebricks, how should I build a pizza oven with them?
Wont' you still have a long joint seam (circular) where each premade arch segment butts up to one another? Here is a pic from Tscar's build showing a staggered bond.
https://community.fornobravo.com/fil...photoid=279192Russell
Originally posted by UtahBeehiver View PostWont' you still have a long joint seam (circular) where each premade arch segment butts up to one another? Here is a pic from Tscar's build showing a staggered bond.
Point taken, if I think about it, even on a dome there is a long seam at each course. So I would do what works for you.Russell
Originally posted by UtahBeehiver View PostPoint taken, if I think about it, even on a dome there is a long seam at each course. So I would do what works for you.
I think I´m going to make use of the fact that the winter is long over here, I´m eager to get started and the kids are away for Christmas, and get some refractory cement and pre-make the arches! If I add a second layer of bricks with refractory mortar on top of the curved firebricks it has to be strong enough. Then a layer of LECA + cement, and then insulation.Last edited by Fizz; 12-20-2016, 08:22 AM.
Came up with another question, that I couldn't find an answer googling it..
Does anyone know if there's any risk in using my indoor fire place to clean the fire bricks? I have a stove that easily reaches the carbon burn off temperature, and could probably fit three or four bricks at a time... I usually fire it up every day during the winter...
The only issue I could think of is the water content in the bricks, but are there any other unknowns in the equation I'm missing?
Started building the base out of leca blocks. No need to cast a slab, as you see ... It´s solid rock...
Next I will build a form and cast a top/slab/hearth (what ever it´s called?) on the base. As you see in the picture, the base is U-shaped, and I wonder how I shoud dimension the concrete top to allow it to be unsupported btw the "sides". It´ll be supported in the back. The distance btw the sides is 80 cm (about 31 inches), and the depth is about 110 cm (app. 43 inches).
How thick should the top be, and do you think its a good idea to build the form like the piece of wood laying on the leca block in the picture? This means that the concrete top won't be supported by the entire surface of the leca block, but the top will use substantially less concrete. The leca block is 19 cm wide ..
Sorry about my bad english, I hope you understand what I mean... =)
I'm not a structural engineer so no exact calculations for below. But from seeing different builds so far:
I would not go with slab thinner then 3.5" (90mm).
I would span the opening of the "U" with something iron .
i would strongly consider at least some sort of arch to help with the weight in front.
IMHO Wood form should go on the outside of the base so the concrete rests fully on it.
Depending on the size of planned oven you might even want overhanging slab , I would not go more then 6" (150mm) or so of overhang.
Rebar is a m must.
I'm sure you will get more structured replies.
Good luck!
Coming along nicely .. =)
I decided to make a support in the center of the concrete slab, and using 90 millimeter of leca, and 50 millimeter of calsium silicate board to insulate the under the oven ...
Any input on the necessity of side support for the arch? I´m thinking of insulating the sides with calsil board and then cast a square ring of rebar reinforced concrete around the 10-15 centimeter lower part of the arch ...Last edited by Fizz; 06-21-2017, 03:18 AM.
To me your perfectly cylindrical dome structure looks solid. It will surely support way more then its own weight. Buttressing the lower part of walls not going to hurt, but IMHO reinforced concrete is way overboard.
Unless what you really building is a reinforced plane shelter to protect your RC combat jet from getting preemptively bombed by your neighbor's RC airforce . Then of course you will need all the steel/concrete you can get
Those arched bricks are turning out quite nice. Good job on herringbone floor.Russell
Originally posted by agrasyuk View PostTo me your perfectly cylindrical dome structure looks solid. It will surely support way more then its own weight. Buttressing the lower part of walls not going to hurt, but IMHO reinforced concrete is way overboard.
Originally posted by UtahBeehiver View PostThose arched bricks are turning out quite nice. Good job on herringbone floor.
More input on the need of buttressing the arch would be much appreciated!
