So as I am still trying to wonk out some issues in my design I had a question. Can I use p-crete to more or less 'shape the outside of my dome to make it not a dome? In this pic you can see what I am trying to do. There will be 2" of ceramic fiber insulation and then 2" of p-crete. What I want to do is build up the corners where the fire brick is essentially covering the firebrick completely to help eliminate water getting into the floor. I don't want to do a full enclosure because the location where this will go is right below a bank of windows on my house. and if I have a large roof structure it blows the view because you would be looking at the side of a roof.
A stucco dome is a lower profile. I would imagine that there would not be any issue with doing so but thought I would ask first. Oh and since someone will bring it up this is a one piece, 42" cast that is cast in place so I need to cast on top of the floor. At least thats how my forms are designed at the moment.
