Curing
  • shanesmith80
    • Nov 2017
    • 23
    Curing
    So its time for fire.
    But before I go crazy with the curing process I thought i'd ask a quick question(potentially silly).
    Where do you take the temp readings from? Are you taking the air temp in the oven, of the brick temp around the walls. I have potential to be able to read both.
    cheers
    shane
    I did both. I was winging it. But, I started out real slow using the Karangi Dude Heat bead "charcoal" method for the first firing. It's a lot more forgiving in the early stages. No matter how small or controlled, a wood fire will have a direct flame impingement at the apex of the dome. That is uneven heating IMO. Just sayin' .
