Originally posted by shanxk8
View Post
Looking for affirmation!
Ready to add the first layer of vermicrete on the dome which was finished just over a week ago. I assume we don't need chicken wire or anything, just mix the Perlite and Portland Cement and apply approx 2" this first time around? Trying to beat the rain...plan on waiting at least a week between each layer of vermicrete. The dome itself it definitely not dry...the mortar is darker in most places, but has been sitting, covered some of the time due to rain, for over a wk. The vent sounds like it could really help if we have significant moisture. thank you!
You may want to cover the vermicrete layer with chicken wire to give some strength to the outer rendered shell. I don't because it takes a lot of time and you also need to make the shell thicker to ensure the chicken wire is properly embedded. I find random fibres a far better and quicker, but more expensive solution. I use AR random glass fibres but there are lots of other options.Kindled with zeal and fired with passion.
I’ve not used this product, but like chicken wire it may be difficult to form it over a dome, being compound curve. Initially I got around this problem by placing sections about a square foot each under the stucco layer as applying it. Far easier and quicker (time is money) to use random fibres. The AR fibreglass fibres I find best as they’re soft to handle and a rough sand of the surface quickly deals with any protruding from the surface. Like I said there are many fibres available.Kindled with zeal and fired with passion.
