Using Heat Stop 50 and Perlite for insulating render
  • gregsbrickoven
    • Apr 2010
    • 12
    Hi all,
    Very new to masonry.
    Is it okay to mix perlite with Heat Stop 50 in a 5: 1 ratio as the render coating? If OK, is it overkill?
    Thanks in advance!
    • 9211
    Yes, it’s overkill as it won’t see high temperature. Normal OPC is sufficient there and as there is a big price difference you are wasting your money. It also has a much shorter working time, potentially increasing wastage if you’re not fast enough placing it.
    • gregsbrickoven
      • Apr 2010
      • 12
      Thank you David! I was thinking it might be overkill.
      • bentedesco
        • Jul 2018
        • 73
        Definitely overkill, I am using quikwall for my render
        • gregsbrickoven
          • Apr 2010
          • 12
          thanks Bentedesco!
