Pictures would be nice to help answer any questions you have.
New member, first oven build
There is so much free water in the vermicrete mix that it's not really necessary, but covering for a couple of days will prevent the surface from drying out. Getting rid of the water is more important. See the attached experiment I did on vermicrete drying that you should find useful. It takes way longer than you would think or appearance suggests. You could try plunging a cheap garden moisture meter into the middle of the layer to get a reading.
Vermicrete insulating slab copy.doc.zipKindled with zeal and fired with passion.
Because you’ve used a proprietary castable which uses CAC then it does not require damp curing. You should probably form a sand mould in front of the oven mouth and cast the flue gallery first, then you can remove the sand and insulate the dome. Then start the drying fires. Getting an uninsulated dome hot, risks cracking it.Kindled with zeal and fired with passion.
If you’ve already cast the flue gallery, remove the sand from the dome, fit the flue gallery and start the insulation. It would not hurt to leave it for a week to let wind and sun do some of the drying, then do the drying fires.Kindled with zeal and fired with passion.
Installing the ceramic blanket prior to curing will minimize temperature differential between inside and outside of your cast dome reducing the potential for cracking. Water vapor will migrate through ceramic blanket. CaSi board (floor insulation) is more affected by water in liquid state. You can install the vcrete after the curing but it will need to dry out before you do you final rendering or coating material.
So I have finished the vermiculite layer. I have somehow used 4 X 100 litre bags and it does not seem quire enough. I've bought a bag of perlite as it's a little cheaper and I intend to use this in a scratch coat render with lime, sand, cement. Then a thin top coat of just normal render.
Firstly is there a problem with doing this?
Secondly what would the ratios be for the perlite render?
1 Photo
