Managed to make some tricky cuts to interlock the serpentine somewhat with the arch on both sides. Hope this holds up. I wonder if I could get away with a brick chimney, even if it were a little short - instead of the SS pipe...We will see...I'm way in improvi-land as it is...
Flue opening measures roughly 11cm * 14/15 cm which is 154-165cm2, for my 32" oven I should be at 175cm2 so a little on small side...
