Challenges and progress of building pizza oven on a slope
  • #61
    I started on the p-crete insulation layer over the ins-blanket. Mixed 60/40 perlite/vermiculite to 8-10:1 cement and threw in a few handfuls of clay powder. Drymixed and added water and it was pretty workable.
    I'm running into an issue though. My oven stand isn't 100% true and plumb. DIY limits on my skills I guess.
    On one side of the dome I am about 1" from the edge, which is okay for rendering. But on the other edge I am only 1/2" from the edge.
    I wanted to render, and then make a brick split veneer like Gulf and others have done. But given my space limitation, I won't have space at least at that narrow ledge to do a full 3-coat stucco.
    If I cast a small cantilever to increase edge space, probably it wouldn't hold up.
    I wonder if I can just make a lime rich render of cement, lime, sand, and trowel it on. Mostly in about 1" thickness, except at the narrow spot. I've got alkali resistant nylon fibers that I'd throw into the mix and then wet sponge to create a smooth surface. I also have a fat based liquid that I found in the home's store here, it is supposed to be mixed with concrete to create water resistance. I would add that to the render mix with the nylon fibers. And then once dry/cured I would consdier to paint it with a wather resistant acrylic (colorless) to max out water resistance, before plastering a brick veneer.
    Anyway, long text here, but just sharing in case anyone has any do's and don'ts for such rendering solution. I'd also consider like DavidS recommendations to keep the render moist - maybe even with cling wrap. But my doubt is - if I cling wrap the fresh render isn't the wrap itself going to create indentations and 'maps' in the render? At least that's been my experience when covering wet concrete with plastic - it destroys the finish...
    One important question also: I have a tuna jaw and some fatty pork marinating. I want to put some coals into the oven today and grill these items. Is it okay to cure the oven with half shell of v-crete drying on the outside?
    My build: https://community.fornobravo.com/for...ress-of-buildi
    • #62
      Decisions decisions lol. Never ends on these projects. Doing the curved roof was probably my favorite decision I made as it broke up the squareness in the yard and gave me a other look that was different than most. Guy on Food Network has a pizza oven with a barell roof I seen it on one of his shows and loved it. Can't wait to see how you finish.
      Ricky
      My Build Pictures
      • #63
        Chach, yes you are correct, lots of things to visualise every night before sleeping. It's obsessive, haha...I've found a blacksmith in the area and will try to ask them what it would cost to cast 4 bows for the roof structure. Won't have to carry much weight so might be possible to do it that way and connect the cast iron to 4by4s as rectangular support strutcure around the dome/hearth. Let's see.
        Fired the oven a few times the last couple of days - starting from coals to small fires and this morning a larger fire with some flames - burnt some of all the forms from the build - felt good. Got the entire dome up to around 200-230C for 4 hours before letting it die down. No cracks, yet....This evening, 6-7 hours later the oven - without door - was still 90 degreesC, so the insulation definitely helps.
        Looking very much forward to really fire it up and see the dome clearing..soon.
        • #64
          This is normal, Gulf has had a bespoke remedy for the edges, https://photos.google.com/share/AF1Q...xFSjZNX1hkSFl3 A great idea and it is non-intrusive and cost effective remedy. Good luck
          • #65
            For only 1/2" of hang over, you can just place a temporary support underneath until the render/stucco sets up.
            • #66
              Thanks Gulf and Alomran. Yes, I did as recommended and added a good half inch of overhang at the narrowest spot - just using a 1:1 mix of cement and sand, mixed quite dry so it wouldn't run on the vertical face, which was a bit tricky. Before stuccoing I grinded some slots into the side of the hearth where the stucco would sit and then 'painted' with a mix of cement and water to create a wet sticky surface for the stucco to bond. It seems to work, but certainly won't win any beauty contest. It matches well the entire DYI-ish look of my oven.
              On a side note, I made our first pizzas in the oven last night. First one came out great, second one not so great. It's a learning process but still a special moment. Important is to have a live flame to create crust, which for the second pizza I only had embers.
              I fired the oven for a couple of hours yesterday, it got up to around 400C on top of dome, 300 on side walls, and around 250 on the floor. The dome didn't clear though... I wonder what the temp has to be for the dome to clear. Insulation works well, hardly any temp difference on top of the dome, and below hearth was only 30 degrees C after firing several hours. I am preparing a piece of pork shoulder to slow cook in the residual heat this morning.
              And also I can record my first cracks. Just hairline cracks in the mortar. Almost symmetric -in the mortar of the flue arch, between 3rd and 4th course on each side.I think this may have happened because I mortared the bottom bricks of the outer arch to the stand rather than letting them float. But, who knows...and it's not structural I think, but I guess I could try to repoint it...if it matters...
              • #67
                Very nice. It is very exciting getting that first pizza for sure. How long did you fire the oven for? It still could be wet but your walls and dome are not nearly hot enough to clear yet. Dome can get to 500 Celsius and higher. 400 Celsius and higher for walls. The bricks have to saturate with heat for a good bour to hour and a half. You probably have to drive more water out if the floor cooled that quick im guessing. You'll get there. Congrats.
                Ricky
                My Build Pictures
                • #68
                  Alright, finally finished the perlcrete iso-layer on the dome. Relatively round. Will let this dry for a good while before figuring out what to cover it with. Also got some steel (1.5mm) and cut/grinded pieces for oven door today. The door will be 10cm (4") thick. I wanted stainless but it's cheaper to weld normal steel, so I will paint this with stove paint to try and keep corrosion at bay.
                  Next is welding this, which I've never done before, gonna be fun.
                  Hope everyone is well, where ever you are, whether locked down or working to keep the wheels spinning.
                  • #69
                    Still haven't finished stucco the oven, but have cooked some pizza, bread and slow cook pork shoulder. It's been great.
                    Firing the oven is not difficult but managing the fire and temperature for the right temp at the right dinner time is a learning curve I haven't mastered yet.
                    I finished welding my door. It's 16 gauge / 1,5mm mild steel with heat resistant stove spay paint and 4"/10cm of leftover inswool insulation in the door. I'm swell proud of the final result, the black stove color makes it look, well...awesome I think. The welds were not pretty, because this is my first real weld job, so still trying to figure out how this thing works...but the angle grinder is my friend. I mig welded the thing, and I think (hope) it holds up. The door is inspired by others who came before me here, among others UtahBeehiver with the wooden handles - I used wood from a peach tree that had gone down in last autumn's taifun. And also JRPizza who pointed to the importance of making a real thick door and for sharing the great idea to weld the nuts onto the inner sheet so that the handles can be unscrewed if necessary later on. Thanks!
                    • #70
                      A couple more photos of the door. I put some bbq insulation tape around the inner lip. Let's see it should improve heat retention.
                      • #71
                        The door will dramatically help with maintaining the heat in the dome.
                        • #72
                          Thanks Utah, yes I am hoping that...can't wait for next firing session to try it out.
                          By the way, I've seen from your build album and from posts in the forum that you have both such an inner door and also an outer door for your wfo.
                          Now I am wondering if I can make my oven more fuel efficient. So here my question:
                          Do you ever use the 'outer door' when firing your oven? Does it make it heat up faster? Or what is its main purpose? I'm just thinking if I should also weld an external door to use when maintaining a live fire in the oven, or whether such a door (most likely without a window anyway) would make it more of a hassle to bring the oven up to temps...
                          Such a door would necessarily need breathing slots though to not kill the fire and turn it into a smoke mayhem.
                          • #73
                            I don't have an outer door. You may be thinking of Gulf, he has an outer storm door to keep rain out. I think his also has a blast inner door as well.
                            • #74
                              Oh yes, that maybe the case. Anyway, I find even using the inner door at the very front during firing creates a draw like in a stove and no smoke escapes out the outside, so that's just great. And your build has always been one I've returned to time and time again for inspiration and information. I had your google album open in a tab in my browser for months.
                              • #75
                                I started on the p-crete insulation layer over the ins-blanket. Mixed 60/40 perlite/vermiculite to 8-10:1 cement and threw in a few handfuls of clay powder. Drymixed and added water and it was pretty workable.?
                                Hi YokD,
                                I am right in thinking that you added this layer before you began the curing fires?
                                i wrapped 3” of fiber blanket and chicken wire and began to cure. im getting toward the latter stages of my curing fires now (700f) and wonder when the best time to apply the v-Crete layer is?
                                also what type of cement and ratio to use with the vermiculite?
                                many thanks.
                                My Build:
                                https://community.fornobravo.com/for...and#post423032
