Getting Started. A few questions about dome layering
  • SergioPizzaiolo
    • Jul 2020
    • 2
    Hi everyone i'm looking forward to build a wood fired oven for a small pizzeria.
    I've been researching a lot for two months by now but i have a few questions about the layers that build up the oven dome and dome inner shape
    First my layers. I bought firebricks (8" X 4" X 2") and heat resistant mortar to build the dome. Then a aluminium foil layer with a wire mesh to keep in place. Then concrete cladding with sand, portland cement and lime. Then a insulation layer with ceramic fiber blanket of 1" . Finally a insulation layer with a mix of vermiculite, portland cement and lime. Is this one a correct layering?
    Second, what is the best oven dome shape. The spherical one or the ellipsoidal ?
    Thanks.
    • 5262
    I suggest you download the free eplans from Forno Bravo, the plans will give you a good baseline for design, construction, materials for a wood fire oven.
    • SergioPizzaiolo
      • Jul 2020
      • 2
      Thank, can you share a link or a direction of where i can find it out in the website?
