Hello! I'm chronicling my build in the Pompeii forum and realized it is for questions of Hearth design and chimney's yet others are putting their whole build there too? Not sure where I should post to get eyes on to get help? I'll post my questions about where they seem most appropriate. My build is in Pompeii construction thread Reviving Pizza History in the Hammer!
So - to my question - I laid out the first course of block and found my slab finish compromised the stability of the blocks (the lads helping insisted on a beveled edge and broom swept - made lots of uneven-ness that I now have to compensate for! - arg!). So - decided to mortar down the first row of block and introduce myself to masonry! I think it went on a bit dry (took a long time to do - learning - and got drier - but did work out - very stiff, 90 degree corners and mostly level). That said, as I did so, I thought I was following the line - but my linear lay is about 1/4" out (bows in) on one side.
Is that a problem? Can I correct subtly on subsequent courses going up?
Also - dry laid bricks on top and found that they are not lining up on one side (wood door opening) - seems the 1/2 block are not true halves of the full!! I have pics below - and again - is this a problem or will it just be hidden by future cladding (do I need to grind flush? Very frustrating!
HELP!
HELP!
