Dreamer turning to "do-er"
Well, it looks like something you'd see at a country lodge! I think our FB hosts have an oven picture contest - you should consider submitting some beauty shots
👍 1 -
Thanks guys. I couldn't have built the oven without the help of the good folks on this site! The last few weeks have been really busy - as you can tell! I confess that I hired professionals to do the stone work. I'm extremely pleased with their work and how the entire project has turned out. Looking forward to many years of enjoyment ahead!👍 1Leave a comment:
Wow Blair! Brilliant work! Looks fantastic. Well done.👍 1Leave a comment:
I decided that I'd do a render coat. I have six 4-foot bags of vermiculite. I used 3 to coat the dome to this point. The remaining 3 I'll pour straight over the dome once I build the doghouse walls. My thought is that I need to remove my portable shed covering in order to build my walls and roof and to allow room for my mason to build the chimney so I might as well get the insulation protection layer on the dome now. I've got a pro doing the chimney in a finishing brick and stone finish. He starts once we get the walls built which will hopefully be in early April. I did put a ceramic rope heat break between the inner arch and the outer archway.
Basically you want a material that is both flexible and not conductive. Forget high temperature silicon in that position, it is too hot for it. The idea is to use material that is a bit flexible and one that is fireproof and is not conductive. Any fireproof calks that I’ve tried set hard when heated and are no longer flexible. Correct me if anyone has found a product that doesn’t go hard. The ceramic rope remains flexible and a lean vermicrete brew remains a bit flexible.Leave a comment:
Thanks Deejayoh! We have a pottery supplier in the next town over. I'll check with them or purchase online.
on the vermiculite, I've heard that it's hard to have TOO much insulation so I want to push that envelope. As you say, I can't really add it later.
I used Kaowool high-temp caulk, and it worked great. You can find it at pottery suppliers - https://www.sheffield-pottery.com/Hi...wool-p/tcm.htmHi all. I have a couple of questions:
I’m planning an expansion gap between my inner arch and the entryway. I have 1/2” ceramic rope to fill the gap but wanted a high temp silicone as well. Having a hard time finding this locally. Even our two local fireplace stores don’t carry it. What temp rating should I be looking for on this silicone?
i am building a doghouse style cover over the dome. Once I lay the FB blanket down I plan on a coating of mortar and then vermiculite over the entire dome. I have four bags of vermiculite, each 4 cubic feet. Would it be ok to just pour this loose over the dome or should I make a mix of v-Crete ?
As for the vermiculite, you can pour it in loose. no need to form it, just fill up your doghouse. Personally, I think that's overkill if you've put on a few inches of blanket, but then again - you can't really go back and add it later.Leave a comment:
i am building a doghouse style cover over the dome. Once I lay the FB blanket down I plan on a coating of mortar and then vermiculite over the entire dome. I have four bags of vermiculite, each 4 cubic feet. Would it be ok to just pour this loose over the dome or should I make a mix of v-Crete ?Leave a comment:
Well Blair, when I started mine, I'd never laid a brick in my life! LOLLeave a comment:
Thanks Mark. It has been challenging for someone with zero masonry skills and few mechanical skills!Leave a comment:
Been a busy week. I have my dome finished! It sure won't win any awards for beauty but should be functional. I'm amazed at the amount of fireclay left after cutting! I've given the dome a coating of homebrew and will do another over the FB blanket next week.
The "bump" at the top is a result of a full brick that I covered in mortar when I covered the keystone in the dome. Just thought the extra depth and insulation wouldn't hurt rather than cutting the brick to just fit over the keystone. Since I'm building a doghouse enclosure, the aesthetics of the exterior aren't high on my agenda.
Moving on to planning the chimney...
JR, makes more sense after I re-read the post. The joints are fairly wide on the exterior end but I have seen many ovens built this way. Only would caution those who use a commercial mortar such as HeatStop to be a little careful on joint size since the recommended joint width not exceed 1/2" although I have seem some builds with HeatStop or equiv. with much larger than 1/2" joints.Leave a comment:
That is truly one beautiful setup you have.
