Okay so I thought I got a great deal on firebricks so I went ahead and bought them turns out they are insolating firebrick I have 215 of them am I out of luck or can I use them to construct the pizza oven? I was thinking about buying some regular firebrick for the floor? Or would I be fine doing the whole thing in insolating firebrick or am I screwed and have to buy all new firebrick? hopefully someone can help me out my wife is pissed that I spent $500 and I might not be able to use them
Insulating firebrick for pizza oven
I did a test by making a small oven with insulating firebricks. It works for pizza but it is sensitive to fire management. Better than a steel oven, but worse than brick oven. Mass acts as a heat buffer. Also, forget retained heat cooking with only IFB.
You still need dense for the cooking floor.
My next oven will be with dense firebricks, but the build with IFB was fast and fun though.
What is their density? You may very well use them as insulation. -
Awsome that’s good to hear I think I’m going to do some more reading and postpone the build until I can buy some real firebrick and either try to sell these or use them as insulation.
I’m not to sure the density I tried looking online but couldn’t get a straight answer how to determine the density
they are 9x4.5x2.5 and they weigh 818 grams
thanks for the help by the wayComment
Sounds like a good plan. Your bricks have 0.49 g/cm3. This gives about 0.13 W/mK or half the insulation capacity of CaSi-board. Stand them tall under the cooking floor and you will have very good insulation. 4" is your minimum if you are height restricted.
Many of you ready know all this, I wrote it to give guidance for those who just started to learn about building their own wood fired oven. If it is in the wrong section, please move this thread. What is insulation? Here is a very short literature study: Insulation is a material whose purpose is to stop heat flux from one
