How much SS needles for 3:1:1:1 mix? How to spread out in mix?
What David Said. When I added them to my bagged mix I figured the percentage PER bag (aprox I didn't go crazy with precise grams) since your using a home brew its best to add them to each measured batch.
Originally posted by mefornaioSS Needles go in the DOME (if your casting it yourself) not in the mortar mix that holds the bricks together.
Hi everyone. I am planning on using the homebrew 3:1:1:1 mix. I have finally tracked down all of my materials! I am just wondering, say, if I use 3 shovels of sand, 1 shovel of cement, 1 shovel of lime and one of fireclay how many needles I should put into this per mixture? I have the recommended 10 kilos of needles for the size of dome I am making, but am unsure of how much I should disperse them throughout each round of mixing! Do you eyeball it until it seems like they are well distributed in the mixture?Tags: None
