Hi --
I am getting ready to start the construction of my oven stand (cement block with cement top) and I have read a lot in the forum about keeopign the insulation dry attaching the chicken wire etc. But I am still unsure as to how to proceed.
If I construct the concrete slab that the oven sits on I am seeing the following --
Elevate the silca board off the concrete using tiles to allow drainage to weep holes in the slab.
But what I don't understand is how to attach the chicken wire -- Do I screw it into the slab? Or Lay it on top of the insulating board and under the firebrick and wrap it up the side?
II I understand things right when the oven is built on the slab there will be an area around the perimeter of the slab up to the oven that will need to be finished to a counter. How do people finish this? Would a concrete counter top be acceptable or is there a better alternative?
My plan is for the oven to be uncovered and I will apply stucco and tile for waterproofing. But given what I read about keeping the insulation on the floor dry how does one accomplish that?
Appreciate the patience with the newbie.
Bill
Bill
