Could you just finish the end with half blocks and return on the 45 like Russell's picture in post #7?
New Modular Corner Build
If you cut half the angle on each ends of the blocks they will match together perfectly..
You don't need angle iron support under the opening. The top slab is more than adequate over that distance.Comment
Start at the 45 degree corner and fill in the gap. you are trying to March to the 45 when you should establish your 45 and work your way out.
Ricky1 PhotoMy Build Pictures
https://onedrive.live.com/?authkey=%...18BD00F374765DComment
