Help with hearth and landing size
  • 130mountainside
    • May 2008
    • 26
    I am buildiing a Pompei oven INSIDE my kitchen. The constraints of the layout have limited my stand to 41" wide to 36" deep. Can the depth be increased through the use of a cantileavered landing?
    I am backing into the dimensions...2.25" deep bricks ( I am in thermal mass school that wants a shorter heat up period), 3" insulation and .5" fireproof backer board. Based upon these numbers I am looking at an oven hearth of about 28". How do I design the opening height/ width- use the 67% of oven height rule? How does one design the landing area? exactyl over the slab? or use cantileaver to extend it a bit?
    Rebar- I have peices longer than necessary for the support matrix. Can I just bend the peices instead of cutting them and wire them together?
    Any photos of this stage of the project?
    THANKS
  • Dutchoven
    • Apr 2007
    • 931
    Re: Help with hearth and landing size
    Originally posted by 130mountainside
    Can the depth be increased through the use of a cantileavered landing?...you can cantilever part of the landing without much trouble
    How do I design the opening height/ width- use the 67% of oven height rule?...door height should be about 63% of interior dome height...as far as width I think most ovens are 16 to 18 inches...I guess about equal to the radius of your oven dome might be a good estimate...then round up
    Rebar- I have peices longer than necessary for the support matrix. Can I just bend the peices instead of cutting them and wire them together?...I wouldn't see any reason why you couldn't
    THANKS...no problem at all
    Best
    Dutch
    • asudavew
      • Jul 2007
      • 1880
      Yes, check out Ken's thread or mine.
      Hire a professional
      Just bend em.
      Plenty of photos here.... just look through them
      THANKS
      You're welcome.
      Dave
      My thread:
      My costs:
      My pics:
