deciding whether to build or buy oven
  • Philip A
    • Jun 2022
    • 1
    Hello, Philip from south texas. My wife wants me to build an outdoor oven, so I don't cook pizza in the house. I've thought about buying a pre-assembled (like an ooni), but understand the openings are so small, and the heating so uneven, that you have to rotate the pizzas multiple times and it's not that easy to do with the limited size of the opening. Still haven't ruled that out, but I have one advantage over most of you. I have a crew with 2 stonemasons and several other laborers. If i do this, i will incorporate it into an outdoor kitchen. There are many considerations, and I don't know what I don't know, so I hope I'm in the right place, and I hope by going through all these design considerations, it will be helpful to others, not just myself. I'll throw out a few of the considerations and questions to start, knowing that that will lead to more questions. I should say that I don't have any qualms about starting big, since I have a qualified crew. I want it to be beautiful.
    1) I would like to be able to cook multiples at a time, in order to host pizza parties. But I don't want it to waste too much fuel. Any thoughts on how this can be accomplished.
    2) Is wood burning the only way to go, or is it possible to use gas, or preferably either gas or wood, or wood burning with gas to start the wood. I have access to natural gas.
    3) Is there any way to build one that can slow cook pork butt or brisket, without getting all that grease all over your oven?
    I'll start there, thanks in advance for responding/
  • AndreasP
    • Jul 2021
    • 126
    Philip, welcome to the forum. There is tons of information here. It's how I was able to build my oven.
    Building your own is certainly the way to go in my opinion.
    My oven is on the smaller side, 32" diameter, but once it's hot it takes less than 2 minutes to bake a pizza.
    I still have to rotate the pizza, since the fire is on one side, but not a big deal.
    I didn't have space for a bigger oven but am pretty happy now that I didn't build it any bigger. When we have parties we have everyone build their own pizza and then I cook then. I'm baking the pizzas faster than most people make their pizza, but then again, we only have space to prep two pizzas at a time.
    So unless you want to make other foods and need more space I wouldn't go too big.
    Just my thoughts.
    Andreas
    My oven build thread https://community.fornobravo.com/for...y-32-cast-oven
    • MarkJerling
      • Oct 2020
      • 813
      Welcome Philip!
      I think most people get more enjoyment from a built oven than from a steel oven, but I have cooked in both and you work with what you've got!
      To answer your questions:
      1) I've built a 42" oven and that is large enough for 3x 12" pizzas at once. As the pizzas cook so fast (under 2 minutes per pizza) I find that, practically, I seldom cook more than 2 at a time. So, yes, a smaller oven will work for pizza parties.
      2) Gas burners can be used but there are risks, so most of us stick with wood.
      3) Mostly, when you cook roasts, you tend to do so in a pot of some description, so there's no mess in the oven. Ceramic and cast iron works and we have a very large (read giant, commercial catering size) stainless steel baking dish too, which is perfect for the Christmas turkey!
      Kind regards,
      Mark
      (New Zealand)
      • David247
        • Jun 2022
        • 2
        Hey Philip, that is just awful that your wife wants you to get an outdoor pizza oven so you don't have to cook inside, Haha. I am envious that you have stone masons too. I would build one myself but just retired and don't have time so I am in the process of building a block stand and concrete/tiled or granite counter top where I will place a fully assembled 36" Vesuvio. I currently have a supposedly 31" brick oven from another manufacturer which oddly is only 29 inches and it is too small... for me anyway. But it does make nice pizzas and I can turn them out in two minutes also. One disadvantage is that it does not retain the heat, especially on the floor. So I am biting the bullet and getting a real oven.
        A couple of considerations on the size for me personally is to have more room to place things other than pizza, like steak in a skillet and a another one for asparagus, etc. (When yours is finished, heat a skillet to about 700 degrees and throw a thick ribeye in it. Best steak I have ever had!!!), and room to move food closer or farther away from the heat. Too small and you don't have that ability, like in my 31/29" one. I threw together a large compass and drew circles on a big piece of cardboard to actually see the size of several ovens. Then drew circles representing pizzas, skillets, Dutch oven, etc. You can also draw a line across about ten inches out from one side or the rear for the space of your fire.
        Here are my thoughts on your questions:
        1) You won't use as much wood as you may think. The last thing I would want to do is either buy a fully assembled one or go through the process of building one and then regret that it is too small. (Don't forget that you are in Texas)
        2) Building and tending to the fire is part of what makes it fun. I understand that it would be convenient to bump the heat up quick with gas but that just takes the fun out of the experience for me. The extra expense of the burner isn't worth it for me either, But everyone is different.
        3) I say let a brick wood fired oven be an oven and let smokers be smokers. Yes you could maintain a small fire and slow cook in it but you are not going to get much smoke on it. That is, assuming you are talking about slow cooking and smoking it. Again, we are all different and have different needs and experiences, but I consider a brisket without smoke on it a ruined piece of wonderful meat. :-)
        I really enjoy making pizza, bread, and a lot of other dishes in a wood fired oven. It is way more fun than making pizza in an indoor oven and I bet you will love it too. Give it a lot of thought and ask more questions and enjoy. Good luck.
