Angle Iron size
  • Angle Iron size
    I'm building the hearth stand as per the instructions for a Pompeii. I cannot find 3/8" 2x2 angle iron long enough to span the opening? The local home depot and Lowes have 1/8". There are 3/36", but only 48 inches long. Is the 1/8 inch thick enough if I put extra rebar in supporting hearth?
    Mike - Saginaw, MI
    Picasa Web Album
    My oven build thread
    Re: Angle Iron size
    I would keep looking - seems a little thin to me. The iron is supporting your opening block and the weight of the hearth (in that area). Have you tried the masonry yards? They usually carry steel as well.
    Les...
      Re: Angle Iron size
      Hey Mike, I had the same problem! Here's the thread I started on the topic; you might find some good ideas in there:
      Link
      I found some at the salvage yard, but maybe a local welder or metal fabricator would sell you some?
      Picasa web album
      Oven-building thread
        Re: Angle Iron size
        I think I got mine from the local brick yard. I think I had to get 1/2 instead of 3/8 but it works.
