What should the height of the oven dome be if my interior diameter is 34.5"?
Re: Oven Height
Daniel
Dome height is not necessarily influenced by inside diameter of the floor although if you were doing a purely sperical dome the dome height would be equal to the radius. The important ratio is of the dome height to the door height and in that case the door should be 62 to 65 percent of the finished dome height...I might suggest you shoot for a 16 inch high dome and that would make your door height about 10 inches and be maybe 16 inches wide...
Hope this helps!
Best
Dutch
Originally posted by daniel5455 View PostWhat should the height of the oven dome be if my interior diameter is 34.5"?"Making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity. " Charles Mingus
Re: Oven Height
Here is my setup so far.
i have a inner diameter of 34 1/4" the door opening is 18 1/4 " by 14 1/4" high. I wanted to do a dome height of 24" is there going to be a problem with this setup. Also the mortar i am useing is the 1311 formula from the pompeii instructions. Will this work? I only laid 2 courses.
Re: Oven Height
Everything should be fine...trust your research and have fun with the build...post lots of pictures too...they help us help you sometimes
All the best!
Dutch"Making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity. " Charles Mingus
