I have been using HeatStop 50 refractory mortar for my dome. I used two bags, both brown. The third bag I just ordered in is white, and states HeatStop 50 refractory cement (rather than refactory mortar). The dealer told me it's the same, that heatstop 50 is all one product, just an older bag. Is this the case?
HELP - Heat Stop 50 cement?
Tags: None
Re: HELP - Heat Stop 50 cement?
Good question (I don't have the answer).
I had a similar experience with HeatStop50. I used 3 bags, all had identical labels. The dry powder in all bags looked the same. After mixing, the mortar from one of the bags was much "grittier"; like it had a courser sand in it. I laid a few bricks with it and it set up fine so I pressed on.
I think the folks at HeatStop may be having quality control issues. I've never experienced that kind of inconsistency with other bagged masonry products (like Sakrete or Quikrete).
Don't take the dealer's word for it. Find the number for the HeatStop factory and call them directly.Ken H. - Kentucky
42" Pompeii
Cost Spreadsheet ... Picasa Web AlbumComment
Thanks for the help. This stuff costs a fortune, though. I'm not opening the bag unless I'm sure it's the right stuff.Comment
Not sure if Heastop uses valve bags or not, if so it will be on the top left or right side of the bag. Lay the bag flat and stick a long handled spoon through the valve (manufactured hole where the bag is filled). If no valve is present, I agree, don't open it.Comment
According to the Rumford website:
Q. What are the Heat Stop product types?
A. There are only two as follows:
1. Heat Stop in a 1 gallon (15 lb.) pail or a 3 gallon (50 lb.) pail. Premixed and ready to use.
2. Heat Stop-II in a 1 gallon (10 lb.) pail and Heat Stop-50 in a 50 lb. bag. Same producte but different size container. Add water, mix and ready to use.
You might wan to call Rumford at (360) 385-9974 or Superior Clay at 1-800-848-6166.Comment
My heatstop 50 came in a white bag- I think it had been on the lot a while. There were only a few bags left. It worked fine.Comment
Thanks for all of the info. For what ever it's worth, I called CMS industries, the company that makes Heat stop. I actually spoke with Bob Rucker, the President. Nice guy.
He explained the products were likely produced in different facilities, hence the different packaging. He assured me that "for the most part" they would be the same product, and that either one would be "good enough" for my needs. Not terribly satisfying. I couldn't pin him down any further. Nonetheless, I moved on and opened the bag. It seems just fine. It seemed to require less water to achieve the same consistency, although this was not based on a side-to-side comparison, but rather recall of the other bags. Could be because it is cold out today. Either way, it looks and held up just the same.
Onward!Comment
Ahhh... That explains why I had slightly different consistency with my two orders. Thanks for sharing!Ken H. - Kentucky
42" Pompeii
