Steel Dome Oven On A Trailer
  • Grimaldi
    Re: Steel Dome Oven On A Trailer
    Originally posted by Gromit
    That works out to about 50 bags of Refmix. I sure hope you can work out a bulk-buy discount.
    50 bags???!!!! I was guessing more like about 5 bags or less. The dome is a 40" diameter hemisphere approximately 27" tall.
  • Grimaldi
    I had forgotten about this thread until I received an emailed that there was a response.
    The project is unfinished, but I hope to get it done this Fall. I cut the tank...that was a lot of fun. I let it air for a good while and then filled it half way with water (once it was filled with water up to the openings where the fittings previously were, I blew it out with compressed air) and started cutting. No issues at all.
    Basically, I have just collected materials and tools, mostly from Craigslist. I picked up some real nice firebrick with "MO FLINT" markings and some light weight insulating bricks. Also found several boxes of Durablanket ceramic insulation, steel plate, cutting torch, welder, 10" brick saw. Still need 2" square tubing for the frame, vermiculite, and refractory.
    I started this with zero metal working equipment and have spent a lot of money on all of this stuff, but more to go...and then get the thing built!
    Thanks for the reminder. I need to get this project back on track.
  • Gromit
    Originally posted by Grimaldi
    The idea is to use the Forno Bravo ref-mix (4" or so) over the steel dome, followed by ceramic insulating blankets and then stucco.
  • pacoast
    I'm sure that someone like Wiley who has already done this would have a lot more useful information. If you haven't already, do read his thread on building a steel dome oven. I haven't read Wiley's thread, so I'm just posing a few questions off the top of my head.
    1. Make sure that you know how to safely cut open a propane tank. Having it explode wouldn't be fun.
    2. Compare the thermal properties of steel to firebrick.
    3. What is the expansion rate of steel compared to firebrick? You will probably have to make some allowance for two different rates. Possibly expansion joints.
    4. Go read Wiley's thread again & any threads by anyone else who has built a similar oven.
    Good luck.
  • Grimaldi
    started a topic Steel Dome Oven On A Trailer
    Hey Everybody~ I'm preparing to build a steel dome wood-fired oven on a trailer using a used propane end cap...40" (thanks Wiley ).
    One of the issues I am trying to consider is heat loss from the steel dome connected to a metal support frame (base). I want to securely attach the steel dome to a base...at first I was thinking of welding the dome to a steel plate laid across the base and insulating underneath (vermiculite concrete and insulating board) and on top of the steel plate, but I think the heat will be drawn from the oven using this method? Or, I could build a steel base with a few welded attachment points recessed within the base frame and buried in light-weight concrete or vermiculite-concrete?
    The propane tank I have is still intact and I was thinking I might cut it leaving about 6" or so below the seam where the hemispherical end cap is welded to the cylinder and use that space for a double fire brick oven floor and insulating board (including 2" or so of the dome/cylinder walls buried in the base vermcrete)...the seam would be flush with the top of the oven floor.
    I'm still trying to figure it all out...but I have the propane tank, a 5' x 10' single axle (3000#) trailer. Forno Bravo has the ref-mix, insulating board, and ceramic blanket insulation, and I can locally source the fire-brick.
    Any ideas to think this through would be appreciated.
    Thanks,
    Bob
