does the vermiculite have to be mixed with concrete or can it be loose under the brick floor.Lay down the out line and fill with vermiculite add floor.
Re: floor insulation
No, loose vermiculite won't work, it's fluffy, and will push right out of the way, or compress to uslessness if you tried. The portland makes it into a rigid layer under your oven floor which can't move or sag at the risk of cracking or worse.
If you don't want to mess with the vermiculite concrete, use a refractory insulation board.
