Measuring your Hearth
This is a sticky topic.
  • Measuring your Hearth
    We get a lot of questions on hearth size for the various oven sizes, and as there is not an "exact" hearth size for each oven, I am posting the method for how you can calculate the hearth size that works for your site.
    I am also attaching a drawing that you can use as a worksheet to calculate your hearth size.
    STAND WIDTH
    For oven width, take the exterior width of your oven (oven floor, plus oven wall width), then add 10" for your insulation (1" insulfrax and 4" vermiculite), then add the thickness of your enclosure walls (1/2" for an Igloo, 2" for a metal stud wall, 4" for a concrete block split, etc.)
    For example, a Casa90 (35.4" cooking floor) is 40.1" wide externally. That means the stand for an Igloo enclosure should be 51" wide. 40+10 (insulation)+1 (enclosure walls).
    If you are building a 42" Pompeii oven, you have 42 (floor)+9 (walls)+10 (insulation)+1 (enclosure wall) = 62".
    STAND DEPTH
    For the oven depth, you take the depth of the oven and vent, then add 5" for rear insulation, then wall thickness, and then space for your oven landing.
    The Casa90 is 43.5" deep, including the vent. If you want a 12" landing, the hearth should be 43.6 (oven and vent)+5 (rear insulation)+.5 (one wall) +12 (landing) = 61".
    The 42" Pompeii oven works as follows. 42 (floor)+9 (walls)+6 (vent floor)+5 (rear insulation)+.5 (one wall)+12 (landing)=74.5".
    You can find the dimensions of the Forno Bravo Casa, Premio and Artigiano ovens in the installation guides here:
    Pizza Ovens
    Outdoor Fireplaces
    Wall Insulation
    My oven design is for a 39" dome leaving 4" for insulation all around to a ciircular brick encasement, 2 bricks thick. I would like to increase the floor size to 42" leaving only 2-1/2" for insulation. I was thinking of using some of the soft white insulating firebricks around the bottom of the dome as insulation between the oven wall & outer brick wall. As the dome curves away from the wall allowing more space I can replace the insulating brick with loose vermiculite.
    The white bricks are expensive but I think a bigger oven would be better.
    Any thoughts on this.
    Balty
      Re: Measuring your Hearth
      Hi,
      I have a 42" oven and I've never wished it was smaller. Lots of times I've wished it was bigger.
      I know insulation is very important, but if it where me I'd sacrifice some insulation around the bottom of the oven to gain the space inside.
      If you take the wider dome approach, might be best to get advice from one of the engineers on the very best insulation material for the space you have. I suspect it's a ceramic blanket, but not sure. The blanket could be coated with portland/stucco just like anything else.
      This type of use is pretty common for my oven:
      - JC
        Hi,
        New to all this but building the oven this week. Can I double the insulationg blanket and cut back on the thickness of the vermiculite shell?
          Welcome aboard,
          Definitely. That's what I did. Rather then doing 1" of FB Blanket and 4" of Vermiculite, I used 3" of FB Blanket. It's thinner, better insulated and easier to install.
          Pizza Ovens
          Outdoor Fireplaces
            Originally posted by DanaMac View Post
            Hi,
            Stongly suggest you do just that. Since I could find both products in Dallas, I found out cost wise it was a push and I think the blanket is better. I've built a 42" Tuscan and 50 sf of blanket will provide half again the thickness. It takes about 2/3rds of a box to cover the WFO, I bought a box of 2" and 1" thinking I would get 3" coverage. I'll almost have 4-5" over it when I'm done.
            RCLake
            "It's time to go Vertical"
            Oven Thread
              I was worried about heat transfer to my outer brickwork as I only had 3" of space around the bottom of the dome. I used 1 blanket of insulfrax around the sides & then tamped down any off cuts to fill the gap. I added a second blanket where I could & then filled the cavity with Vermiculite.
              After several hours of the oven at temperature there is absolutely no heat transfer to the outside of the brickwork.
              I added another blanket on top because I poured a concrete slab as my roof & was worried about heat transfer from the top. Again there is none after several hours of using the oven.
                Originally posted by jahysea View Post
                my oven is a meter or about 39 or 40 inches and have stacked oven dishes on top of each other before....terraced cooking I called it.
                Is there a post on relative surface area any where?
                  I'm installing a Premio 100 (39" cooking floor) and am trying to get an exact stand measurement. If I'm using 2 FB blankets for insulation (omitting the vermiculite) would I need to add 10" for insulation using the chart above? Walled enclosure, not igloo style. The smaller the footprint the better.
                    I can only speak from my own one time experience. I had 2 layers of Insulfrax on the sides but compressed into 3" of space & an extra layer on top as I had it left over. Absolutely no heat transfer through the walls or roof.
                    Rgds
                    Balty
                      I am new to all of this and have just laid the first course for a 1 metre internal floor oven. I have picked up bits and pieces of info from you guys on-line. I am doing the door 12'' high by 20'' wide with an internal dome height to be about 20'', does that sound about right.I understand the door heigth is to be no more that 60% of the dome height otherwise the fire won't draw properly. I have laid the 1st course bricks normal side down and then laying half bricks on top, it that correct? One of the things that worries me is the construction of the chimney (the oven is outside). Any help would be most appreciated. cheers... Mulga
                        Hi Mugla,
                        Did you get any responses? I am building a 1 meter interior oven as well and your door height and width are about what I have been planning as well. How far along are you?
                        Rick
                          I am about to put on the final waterproof render. When everyone says you need lots of thermal insulation, they are right, you cannot have enough. If possible use refractory motar, I didn't and wish I did now.
                          After I finshed the brickwork, the dome stayed intact, I did a waterproof render, but I lost lots of heat. So then I did a 50mm perlite and aluminium cement render, a 25mm (1'') superwool blanket and then a 50mm vermiculite render and are about to finish it off. The pizzas had better tast good.....
                          Good luck mate, let us know how it works out.....
                            By chance do you have any pictures of your oven under construction, specifically the door...?
                            I will be using refractory mortar and have built a 4" insulating slab on top of the hearth. Once the oven dome is done, I am planning of framing around it and will fill that space with perilite or vermiculite.
                            Glad to hear you are cooking... my pizzas are still being done in my BBQ on a big flat stone on the grill.
                              How do I get my photos to appear in a post. I uploaded build to my album but no idea how to get the thread in the right place. Help !
                              EatingMoreFood
