Refmix mortar
  • Refmix mortar
    1. I cannot easily obtain fireclay. Any recommendations instead of the sand-fireclay mixture for the underfloor paste? I was going to use either plan sand or a thin layer of Refmix mortar.
    2. Any objections with using Refmix mortar in construction of the vent, chimney, and openning arch?
    Jeff
    Utah
    Re: Refmix mortar
    Hey Jeff,
    Refmix will be perfect for the vent, chimney and opening arch. That area gets hot, so using a high temperature mortar is the right thing to do. Plus, it has a nice, fine grey finish, so it will look nice.
    I don't think you need to go to the trouble or expense of mortaring down your floor bricks. If you can't find fireclay, you can use a bed of fine sand and tap your floor bricks into place with a rubber mallet.
    Would other builders agree with that?
    Pizza Ovens
    Outdoor Fireplaces
      Re: Refmix mortar
      I also found that by time i cut all my bricks in half, i had more than enough dust/sand for underneath the hearth. i still have a bag left over. But it would be a long drive from Calgary to deliver it to you )
        Re: Refmix mortar
        Any idea where you can get refmix or a good refractory cement in calgary?
          Re: Refmix mortar
          i bought most of my masonry supplies, including Heatstop 50, from
          Alomar Building Products
          7107 Fairmount Drive Southeast, Calgary, AB T2H 0X6 (403) 291-4740
          they are not very good at answering the phone or taking messages, but extremely helpful when i dropped by.
          Philip
            Re: Refmix mortar
            Thanks Philip. They were helpful.
              Re: Refmix mortar
              Good luck with the build. i bought some fabulous stone for the oven opening from Alomar too.
