Hi , I recently made a brick oven with a gas burner it works fine but if I try to increase the heat above 150 degree Centigrade it starts to rattle and feels like its going to crack open . Can any one suggest whats wrong ?
fire brick oven heating issue
Re: fire brick oven heating issue
Segalano...
I think the lack of replies to your questions is primarily because everyone here is working with wood fired ovens. The entire design of a construction of these Pompeii style ovens surrounds wood fired cooking. Unless you built the dome to the correct specs, a number of problems can be occuring that would cause it to "crack open". Do you have any pictures of your build? Or explaination of what kind of materials you used?Check out my oven progress here: http://www.fornobravo.com/forum/phot...dex.php?u=4147
See ALL of my pictures here:
