fire brick oven heating issue
  • segalano
    • Oct 2009
    • 3
    Hi , I recently made a brick oven with a gas burner it works fine but if I try to increase the heat above 150 degree Centigrade it starts to rattle and feels like its going to crack open . Can any one suggest whats wrong ?
  • Breven
    • May 2008
    • 251
    Re: fire brick oven heating issue
    Segalano...
    I think the lack of replies to your questions is primarily because everyone here is working with wood fired ovens. The entire design of a construction of these Pompeii style ovens surrounds wood fired cooking. Unless you built the dome to the correct specs, a number of problems can be occuring that would cause it to "crack open". Do you have any pictures of your build? Or explaination of what kind of materials you used?
    See ALL of my pictures here:
