2 1/2 inch steel studs for enclosure?
  • sjdritz
    • Nov 2009
    • 67
    I am planning out my install of a WFO on a custom metal stand. I want the smallest footprint possible. Would an enclosure made with 2 1/2 inch steel studs and cement board be enough. I notice other builds use larger studs for their enclosures.
    Thanks,
    Scott D.
    Re: 2 1/2 inch steel studs for enclosure?
    I wouldn't try to support the oven on sheetmetal studs of any dimension. Most metal stands are made of rigid structural steel welded together.
    If it's just to support the cement board on top of your support slab, I'm sure the smaller ones would work fine. Remember, a round oven only approaches the edge of the square support in three places. You could use the standard studs and cut them away in those three places.
    Remember to leave room for your insulation, whatever you do.
    • sjdritz
      • Nov 2009
      • 67
      Dmun,
      This would only be for the enclosure around the oven.
      Scott D.
      • SCChris
        • Jun 2009
        • 1213
        This studs should be fine for the oven enclosure. Do you have enough room for the needed insulation?
        Chris
        • sjdritz
          • Nov 2009
          • 67
          Chris,
          Yes there will be 4 inches of the blanket insulation and then the enclosure can be filled with the perilite stuff.
          Scott D.
          • SCChris
            • Jun 2009
            • 1213
            You should be golden then.
            Regards!
            Chris
