Curing
  • #31
    Re: Curing
    Here is the graphic. I like this one! :-)
    I think this shows how a small hairline crack on the outside of the mortar (maybe from the mortar drying too fast) really is not important.
    With the FB modular oven kits, you can always go ahead and assemble the oven, do the FB Blanket insulation and complete the enclosure before you start the curing process.
    • #32
      Re: Curing
      Thanks James
      What about the hairline crack that is not in the mortar? It's in the vent section and runs from about 8 inches form the top of the dome all the way to the front of the oven right along the line formed were the curve of the vent area goes vertical forming the chimney. It is clear through as I can see it on the inside of the oven.
      Should I put some of the mortar over it or just put the blanket on and start cooking.
      Phil
      • #33
        Re: Curing
        If the crack is bigger than a hairline, you can pack mortar on the outside of the dome, which will seal it. If it ever gets larger with lots of use (which almost never happens), you could patch it from the inside with a different internal sealing product. I would recommend that you mortar the outside, and then complete you installation and start using your oven! Then keep an eye on it.
        It will be fine!
        • #34
          Re: Curing
          Thanks James I desperately needed to hear that good news. Enjoy your weekend in beautiful Pebble Beach. Love the architecture of the homes in Carmel.
          Phil
