Re: Curing
Thanks James I desperately needed to hear that good news. Enjoy your weekend in beautiful Pebble Beach. Love the architecture of the homes in Carmel.
Phil
Re: Curing
If the crack is bigger than a hairline, you can pack mortar on the outside of the dome, which will seal it. If it ever gets larger with lots of use (which almost never happens), you could patch it from the inside with a different internal sealing product. I would recommend that you mortar the outside, and then complete you installation and start using your oven! Then keep an eye on it.
It will be fine!
Re: Curing
Thanks James
What about the hairline crack that is not in the mortar? It's in the vent section and runs from about 8 inches form the top of the dome all the way to the front of the oven right along the line formed were the curve of the vent area goes vertical forming the chimney. It is clear through as I can see it on the inside of the oven.
Should I put some of the mortar over it or just put the blanket on and start cooking.
Phil
Re: Curing
Here is the graphic. I like this one! :-)
I think this shows how a small hairline crack on the outside of the mortar (maybe from the mortar drying too fast) really is not important.
With the FB modular oven kits, you can always go ahead and assemble the oven, do the FB Blanket insulation and complete the enclosure before you start the curing process.
James1 PhotoLast edited by james; 05-19-2011, 10:57 AM.
Guest repliedRe: Curing
Hi Phil,
The hairline crack in the outside of the mortar is OK and you can go ahead and insulate and finish assembling your oven.
Phil I will also send you a graphic, it wont let me upload it here.
Heidi
Re: Curing
Update - I have finally begun the curing process and like many I have several hairline cracks. Two are vertical in the mortar that covers the seams in the doom (Casa90) and one runs horizontal from the doom into the vent area.
Should I apply Heatstop 50 over the cracks before continuing with the curing process?
BTW - I have not installed the blanket yet.
Phil
Re: Curing
If you have a layer of vermicrete, which holds lots of water it is very important to dry this layer with sunwind and curing fires before applying the outer shell, otherwise you'll get plenty of cracks in the outershell from the expanding steam.
Hello PlanoPhil,
With the FB modular ovens, you can fully assemble the ovens with the mortar, insulation and the enclosure before curing the oven. Be sure to follow the curing instruction included in the installation guide.
If it looks like there will be rain and the oven is not fully covered with your permanent waterproof enclosure, you should cover it with a tarp. Otherwise the oven and the insulation will absorb water -- which is not good.
If you follow the curing instructions, you will be in good shape. The instructions are thorough. As you go through the curing process, you will see that the oven gets hot much more quickly and there is less smoke with you start the fire.
The reason there is some confusion is because some Pompeii oven builders have wider mortar joints, and use home made mortar where there is more water and it takes longer to cure. Also, some Pompeii oven builders like to start curing the oven without the insulation on to see if any cracks develop both inside and outside the oven dome. But these are not issues for FB oven owners.
Thanks,
Heidi
Intranet search results for ciment fondu and calcium aluminate cement
The ciment fondu website says this on their front page -David, it seems to support your assertion for very short cure times:
Now David, this is where you say, "I told you so"....Originally posted by ROCKRETE web siteMain Properties of Ciment Fondu
- rapid hardening allow return to service within 6 hours
- fast drying times - residual moisture below 3% within 48 hours
- resistant to extreme temperatures and high thermal shock
- provides better resistance to abrasion than Portland cement
- resistant to corrosion from diluted acids, seawater, sugar solutions, greases and fats.
By the end of my dome, we had stopped adding lime to the calcium aluminate home brew because it set too fast and had surface cracks visible within an hour or two. I would join those who have already recommended James remove the Lime from the FB.com home brew recipe containing calcium aluminate.Originally posted by The Oreworld trade (Tangshan) co web siteThis cement is not adapted to alkaline environment, do not mix alkaline material such as lime.
Re: Curing
Yes, at least that's what I've read from at least two manufacturers/suppliers. It is a slightly different chemical reaction to that of Portland cement and has a different hydration period. I follow the manufacturers recommendations and cover it for 24 hrs. I find cling wrap really good for this. It generates a fair bit of heat while it goes off.
Will someone kindly talk about curing time for calcium aluminate in home brew?
Can someone please compare and contrast curing for 'home brew' mortars with calcium aluminate and Portland cement?Originally posted by david s View PostThere is confusion about the term "curing".....snip....
Castable refractory containing calcium aluminate cement does not need this treatment. It should be covered for 24 Hrs only....snip....
Reason being, I used 'home brew' mortar with calcium aluminate -brand name ciment fondu- in place of Portland cement.
Are you saying there is little to gain after 24 hours curing in a wet/moist environment?
Re: Curing
mortar is not meant to be really strong as has been previously discussed. You usually make the brew weaker anyway. Typically 4:1 for mortar rather than 3: 1 concrete.
Re: Curing
Scaremongering? not by you, but the industry?
My mortar cant or shouldnt be any stronger yet its only 40%?
How Bizarre?
Re: Curing
It is probably only 40% of its potential strength, But if you think what you"ve got is good enough then you"re good to go.
Re: Curing
After 7 days with no "curing" you cant drive a concrete nail into my mortar, so what am I missing?
