Steel reinforcement in vermicrete
  • RichC
    • May 2013
    • 182
    Hi, I'm pouring my concrete deck tomorrow(I hope) on which will sit my vermicrete slab. Ive 2 questions around this.
    1. Does my vermicrete need to be tied into the slab its sitting on with steel? Im guessing the answer is no but would like some confirmation of this?
    I'm doing a 100mm concrete deck which is tied into the 4 retaining walls that the whole oven sits on. The vermicrete slab(125mm) will sit directly on this. However, the vermicrete slab will be enclosed on 4 sides by blockwork, so I dont have to shutter in the edges before pouring.(hope my explanation makes sense?)
    2. Does vermicrete need to be reinforced with steel/mesh?
    Richard
  • mrchipster
    • Apr 2010
    • 1502
    Re: Steel reinforcement in vermicrete
    No wire or rebar needed, or recommended.
    Chip
    Chip
