Curing with Insulation or Without?
  • #16
    Re: Curing with Insulation or Without?
    Originally posted by Campmaki View Post
    Stonecutter, posted more pictures and my weekend progress. I had what I believe is steam or moisture in my ceramic blanket after starting my cure. You could actually see it rising. Is this common? I had to insulate before I began the cure , because of the "steps" that are in my build. In other words I would not have been able to kept laying up the venneer without insulating first.
    If you covered green masonry with insulation then it's going to hold moisture..so yes, that would be normal to see steam. You do what you gotta do.
    Old World Stone & Garden
    John Ruskin
    • #17
      Just keep slow consistent fires, when you think ithe I insulation is dry, it isn't. Toys over dome clear plastics you will see more moisture. I believe blanket on as it equalised the oven, potentially minimising cracks, others believe off.,
      I cured mine for over a month before rendering. Of course ed cooking while this was happening no point wasting the heat
      Cheers Colin
      Oven 1 Completed
      Oven 1 and surrounds
      • #18
        As a general rule, if you see steam then you are going at it too hard, back off with the fire or risk refractory damage or cracked outer igloo shell.
        • #19
          In general I guess, but I would worry more with a cast dome or a stucco layer...not with a newly closed brick dome.
          John Ruskin
          • #20
            yes that is true.
