Hi folks,
I have a relatively small spot to fit the foundation for a new oven. I have ample room infront of the oven to access it, but there are concrete pavers infront and a concrete fence behind it so the size of my foundation and stand are limited. Specifically, I can fit a 56x56 foundation and the accompanying 56x56 stand made from concrete blocks. Ideally I'd like to install a Casa2G90.
It looks like the dimensions of the oven are 46x40. We then add on 3" at the back of insulation, and 3" of insulation to both sides, bringing up the total dimensions to 49x46. If we add an arch, we're looking at 53x46, which seems to fit on a 56x56 stand.
I would also think I could extend the hearth out slightly from the last block given that it would only be used as a landing and wouldn't be supporting much or any of the weight of the oven.
Any thoughts/suggestions?
