Well, my Casa 2g90 just arrived last night, so I guess it's time to start my thread.
We have a long narrow triangle of a backyard in Portland, Oregon. We wanted a reason to go to the back end of the yard and in a moment of internet inspiration based off a "Build a pizza oven for $150!" youtube video, my wife sent me on my own personal Pizza Quest (which is definitely NOT $150).
We put down a nice circular patio in July 2017, I poured my slab in Sept 2017, built my stand base when it warmed up in APRIL 2018, and we poured the counter in late MAY 2018. So far my only real hiccup was that I think I poured the counter a bit dry, but my concrete friends assure me I'm golden. I guess we'll see if it collapses when I get the oven up there.
Now I'm preparing to lug the kit up onto the main counter and I have many questions:
1) How do I secure the lathe to the oven? Do I screw it to the counter? The insulating base seems very fragile and not a good place to screw.
2) The video shows using two different kinds of stucco to finish, but then mentions that the marble stucco is harder to work with but more durable. Since it will be an outdoor oven, I want maximum durability and waterproofness (I'll tarp it in the winter). So I think I should use the marble stucco for both layers. But am I really going to gain a lot in waterproofing and durability, or is it not worth the extra effort?
3} How can I seal off the edges of the insulating base because it seems like it would wick water and degrade pretty significantly if it's not robustly sealed. I've seen mention of high temp silicone caulk for around the chimney, so I'm currently thinking of putting a big bead of that around the outside edge of the whole oven once it's stuccoed and finished with acrylic.
MANY more questions to come, so bear with me.
My favorite comment to date from a dear friend is: "Seems like a lot of money to spend on a hornet's nest".
PICS TO FOLLOW TO AVOID THE ANTISPAM BOTS
) transferring water to the ceramic board that loves to soak up water. I just did an online search and it appears the Bay Insulation Company in Portland may carry it. The demand wasn't good for the residential market but it still has plenty of value in the commercial market. You might even be able to find a builder with "scraps".
). You can also build a little dam (concrete or mortar) around the finished dome perimeter and paint it with one of the flexible sealers like Redgard (used in shower stalls & floors). Gulf mentioned using something like this for your hearth in his post (#6) above. The final coat of stucco/render would simply cover it along with the dome's lath and insulation blanket.
