Finally getting our concrete counter tops into place and getting ready to start moving our new Casa 90 onto it. Took us a bit of time as we’ve used Buddy Rhodes Craftsment mix in forms for all of our tops. We’re about to apply sealant and had two questions:
-Does it make sense to apply concrete sealer to the countertop underneath the area where our oven will sit?
Insulation and brick will be sitting on top of this and I don’t know how much heat the sealer (also from Buddy Rhodes) can take or if chemicals from the sealer will leach through the insulation and into the oven, brick (and food, oh no!)
-Should we raise the insulation at all, or is it ok if it sits directly on the countertop?
I’m concerned for moisture as the oven will be exposed and we may run the risk of not having a complete waterproof barrier once we stucco the dome insulation and surround everything.
Though it doesn’t rain often here, there’s a chance that water will pool when it does, and seep under the dome/into the insulation. I’ve read that some folks have pull drainage/weep holes in their tops to account for this, but would love to void this if possible.
I’ve uploaded the only pic I have of our build on this computer. Oven will be going in the corner of the “L” on the island. Thanks for the input and all the great forum content so far!
