Hi Everyone!
I trying to build a 42" oven based on the plans provided by Forno Bravo. Getting all my insulation and venting materials together for the installation.
Where is the best place to get an oven door based on the standard size outlined within the plans? If a door has to be custom made, where would be the best place to look.
I see a website called "Old West Iron" that makes custom doors. Is there anywhere else to consider?
) or hire a local metal shop make one. Again as he noted, your oven is/will be "custom built" so expecting to find a good fitting door off the shelf is a bit unlikely. Hope that helps.
