Inset FB Board in Cement
  • mandrews0809
    • Oct 2020
    • 9
    I just received my FB Girando70 and had a question about the ceramic board. I have the stand already build and the oven is going to be supported by 3 inches of structural cement. I planned on then placing the 2 inches of ceramic board directly on top of the 3 inch cement, and then pouring additional cement around the fiberboard so the cement is level with the fiberboard. Is there anything wrong with that ? Hope that makes sense thank you
  • SableSprings
    Moderator
    • May 2009
    • 1310
    Welcome to the Forum community. We do not recommend placing ceramic board directly on concrete. Most types of insulating boards and batting for a wfo readily absorb water. The current best practice (least expensive) is to drill or use tubing to form some 1/2" drain/weep holes through the concrete hearth and lay some sheets of porcelain/mosaic file on top, so the spaces between tiles "lead" toward the weep holes. The ceramic board is then set on top of this water barrier. Concrete can wick moisture to the board without this barrier/drain system. Without some sort of drain/weep system, the "embedding" of the board actually creates a trap for any water or moisture that finds its way in (and water is VERY good at that ).
    There is really no need to go to this embedding step. Your goal is to isolate the oven from potential moisture intrusion (while providing an escape route) and completely isolate the wfo with insulation. Lots of well documented builds on the Forum that illustrate and discuss the "why". Hope this helps a bit...but keep posting your questions...the more research and time you spend planning before the build, the happier you will be down the road.
    Roseburg, Oregon
      Some coarse aggregate that has some decent air spaces throughout the layer would also work equally well but if a vermicrete slab is cast over it some shade cloth or weed may should be placed over it to prevent those spaces being filled. Same goes if tiles are used.
      • mandrews0809
        • Oct 2020
        • 9
        Thank you for the info. Another question, I was debating on whether to have one or two layers of fiberboard (I have the 2 inch thick board). Under the board is 3.5 inches of regular concrete. Also, I can place the bricks directly into of the FB Board, right ? I plan to add a very light layer of the mortar provided (dry) to ensure a perfectly flat surface.
        I'm not looking to have massive heat retention though
        • SableSprings
          Moderator
          • May 2009
          • 1310
          Two inches of ceramic board underneath your oven is enough. Many people who want much longer heat retention may choose to add more than 2", but for normal use, one layer of the two inch stuff is enough. That said, the mantra here has always been, more insulation is better...you can't add it underneath once the oven is built. I have an equivalent of 2" of FB board and am very happy with the amount of baking I can do from a single firing. (Also, don't forget the water barrier/escape system beneath the board...it's very important.)
          Most people simply use a thin layer of sand with a little clay mixed in for the leveling on top of the board. Use a grooved tile trowel on your sand/clay layer and then lay the bricks directly on top, tapping them in level. You don't need to use dry mortar and in fact it will also pull moisture from the air and "clump & stick". Not that it's a problem, but if you ever do want to replace one of the bricks if it is damaged...the mortar may make it more difficult to replace than it needs to be. If your boards are level, there is no need to lay sand/clay on top...simply lay your bricks down on the board.
          Roseburg, Oregon
          • NCMan
            • Jan 2014
            • 846
            I agree. For your use, one layer is fine and I wouldn't embed it at all. It needs to stay dry, both during and after the build.
            My Build:
            • mandrews0809
              • Oct 2020
              • 9
              Thanks, only used one layer. However I did inset it kind of out of necessity/aesthetics but I took some moisture precautions.. painted the edges w high heat paint , put weep holes under the board, raised the board on ceramic tiles (backsplash type) so water could channel to the weep holes, and put foil on the edge so the board didn't wick away cement moisture.
              • SableSprings
                Moderator
                • May 2009
                • 1310
                I've attached a link to a build that documents the use of a "waterproof" layer between the concrete and the oven insulation board quite nicely. Posts 8-18 discuss the options & post 19 has a great illustration of use of mosaic tiles as a moisture barrier & how the gaps provide a gateway to the weep holes. Fifty mm (two inches) of CaSi board is considered minimum (and completely adequate ) base insulation. Many builders have chosen to add an additional layer of insulation below the CaSi board and often the 5:1 perlcrete or vermicrete is used because it's very economical. The insulation value of 5:1 insulating concrete calls for about double the thickness of CaSi board...so 100 mm of insulating concrete is approximately equal to 50 mm of CaSi. Since it's relatively inexpensive, choosing to have 100 mm of insulating concrete on top of your moisture barrier (separating the concrete & the oven insulation), then adding your CaSi board which is just underneath the cooking floor bricks makes for an excellently insulated oven. (Don't forget that you want your entire oven insulated from the concrete hearth foundation...so the insulation extends underneath the dome bricks as well...).
                I don't know if your quarry stone will wick moisture or not...if you decide they will work, (and you decide to pour insulating concrete over them) you'll want to put a layer of garden cloth over the quarry tiles to prevent the mix from clogging the channels to your weep holes. That's why I like to see the mosaic tile sheets laid upside down on the hearth...keeps the channels clear.
                I've been reading posts here on and off for a few years while thinking of building a WFO. There is an amazing group here. Originally, I wanted to do my build from scratch but decided not to for various reasons and instead purchased a Casa 2G 90 kit. It arrives today and I'm getting ready to pour my concrete
                Hope this helps...and remember that you should be able to find discontinued mosaic tile sheet patterns or left-over sheet squares at bargain prices.
                Roseburg, Oregon
