Vermiculite with no blanket
  • Rslt
    • Nov 2020
    • 2
    Hi, hope I don't get a collective groan but have searched and not found an answer.
    Can I skip using ceramic blanket and apply only vermiculite as an insulator on the exterior of the dome?
    Thanks in advance
  • MarkJerling
    • Oct 2020
    • 813
    Yes you can, but vermiculite cement is a much poorer insulator than the blanket. Of course, if you built a "house" for the dome, there's nothing stopping you filling the resulting cavity with vermiculite. That will work well, but vermiculite cement is a poor insulator.
    • Rslt
      • Nov 2020
      • 2
      Ok, thank you, appreciate it.
      • Petter
        • Feb 2020
        • 210
        Has anyone seen or experienced any cracking in the outer render as a result of not having the blanket as expansion joint between the dome and perlite/vermiculite concrete?
        • MarkJerling
          • Oct 2020
          • 813
          Yes, two friends of mine built such an oven and the outer render has cracked badly.
          • Petter
            • Feb 2020
            • 210
            Great info, Thanks a lot!
            • Chops
              • Jul 2021
              • 13
              What Grade of Vermiculite should you use When applying to your Dome & Floor areas ?
                Yes I’ve cracked the outer shell of an oven that had no blanket. The problem is that a very thick vermicrete layerwill still have a lot of moisture deeper in and particularly where it contacts the inner dense dome.If this suddenly turns to steam you’re in trouble. I simply rendered another layer over the cracked outer shell after several more drying fires to drive out the moisture. After that experience I began doing layers of vermicrete no thicker than an inch and a half thick, with a week of drying before adding a subsequent layer. When the safer blanket became cheaper I started using it instead of a vermicrete only insulation layer.
                Any grade of perlite or vermiculite will work, but the finer grade requires more water and as it is a problem to remove, it’s not a great choice. The coarse grade doesn’t hold together so well, particularly with the leaner mixes. I compromise and use a medium grade.
